查看: 4851|回复: 2
caxa2015安装后不能打开
发表于 2015-11-4 14:18:28 | 显示全部楼层 |阅读模式
这是安装后打开,出现的错误报告,诸位大神请指教!<div><div>&lt;ExceptionInfo&gt;</div><div>&nbsp;ExceptionType: Unhandled</div><div>&nbsp;DumpLevel: Normal</div><div>&lt;/ExceptionInfo&gt;</div><div><br></div><div>&lt;ProductInfo&gt;</div><div>&nbsp;Product name: CAXA CAD 2015</div><div>&nbsp;Version: 15.0.0.5751 (x86)</div><div>&lt;/ProductInfo&gt;</div><div><br></div><div>&lt;SystemInfo&gt;</div><div>&nbsp;OS: Windows XP 5.1(2600) Service Pack 3</div><div>&nbsp;Total Physical Memory: 2013 MB</div><div>&nbsp;Available Physical Memory: 1182 MB</div><div>&nbsp;Total virtual Memory: 2047 MB</div><div>&nbsp;Available virtual Memory: 1601 MB</div><div>&lt;/SystemInfo&gt;</div><div><br></div><div>&lt;ProcessInfo&gt;</div><div>&nbsp;Error Count: 3</div><div>&nbsp;Total:2047.94 MB &nbsp;</div><div>&nbsp;Free:1601.02 MB&nbsp;</div><div>&nbsp;Commit:385.07 MB (Img:145.57 MB Map:147.64 MB Pri:91.87 MB)&nbsp;</div><div>&nbsp;Reserved:61.84 MB (Img:0.00 MB Map:9.10 MB Pri:52.75 MB)</div><div>&nbsp;GDI resource handle count: 1175</div><div>&nbsp;User resource handle count: 491</div><div>&lt;/ProcessInfo&gt;</div></div><div><br></div>
发表于 2015-11-6 11:32:20 | 显示全部楼层
重启一下试试,可能相关依赖程序没有安装上
如果不行,卸载重新安装,安装时把杀毒软件关掉。
 楼主| 发表于 2015-11-9 14:12:49 | 显示全部楼层
回复 2楼caxtest的帖子
谢谢,安装了最新版本就可以打开了
GMT+8, 2024-11-24 11:05 , Processed in 0.124872 second(s), 18 queries .
