查看: 6526|回复: 9
实体设计中为何不能读入文本文件绘制样条曲线?
发表于 2014-3-20 20:48:18 | 显示全部楼层 |阅读模式
我按照《CAXA实体设计2011实例教程》中读入文本文件绘制样条曲线的操作步骤,在CAXA实体设计2013中却无法生成三维曲线!总是提示“读文件的1行时发生错误”,不知道是何原因?请高手指点!
发表于 2014-3-20 21:07:03 | 显示全部楼层
楼主给个具体是数据例子,大家都来试试
 楼主| 发表于 2014-3-20 21:27:13 | 显示全部楼层
x        114.753        y        -78.331        z        98.994
x        114.766        y        -78.31        z        98.498
x        114.876        y        -78.149        z        98.039
x        114.91        y        -78.099        z        99.395
x        115.971        y        -77.715        z        99.572
x        115.45        y        -77.302        z        99.612
x        116.526        y        -75.674        z        95.287
x        117.536        y        -74.087        z        98.278
x        118.455        y        -72.806        z        93.097
x        119.352        y        -71.124        z        96.108
x        120.406        y        -70.019        z        90.822
x        121.101        y        -68.22        z        93.806
x        122.396        y        -67.33        z        88.465
x        122.882        y        -65.414        z        91.41
x        124.445        y        -64.755        z        86.034
x        124.719        y        -62.722        z        88.927
x        126.577        y        -62.298        z        83.551
x        126.633        y        -60.155        z        86.371
x        128.648        y        -57.723        z        83.76
x        128.814        y        -59.967        z        81.039
x        130.791        y        -55.432        z        81.125
x        131.176        y        -57.769        z        78.523
x        133.077        y        -53.279        z        78.494
x        133.679        y        -55.7        z        76.033
x        135.529        y        -51.258        z        75.906
x        136.331        y        -53.747        z        73.606
x        138.151        y        -49.359        z        73.395
x        139.144        y        -51.9        z        71.278
x        140.951        y        -47.561        z        71.005
x        142.12        y        -50.143        z        69.087
x        143.925        y        -45.844        z        68.77
x        145.249        y        -48.454        z        67.063
x        147.06        y        -44.179        z        66.725
x        148.517        y        -46.806        z        65.234
x        150.343        y        -42.543        z        64.901
x        151.911        y        -45.177        z        63.631
x        153.751        y        -40.909        z        63.32
x        155.408        y        -43.545        z        62.27
x        157.259        y        -39.252        z        62.003
x        158.985        y        -41.889        z        61.174
x        160.841        y        -37.557        z        60.963
x        162.617        y        -40.188        z        60.364
x        164.463        y        -35.801        z        60.203
x        166.272        y        -38.431        z        59.819
x        168.101        y        -33.983        z        59.707
x        169.91        y        -36.61        z        59.381
x        171.707        y        -32.088        z        59.259
x        173.509        y        -34.713        z        58.941
x        175.274        y        -30.122        z        58.816
x        177.068        y        -32.742        z        58.503
x        178.802        y        -28.085        z        58.372
x        180.586        y        -30.696        z        58.068
x        182.289        y        -25.978        z        57.932
x        184.064        y        -28.583        z        57.636
x        185.739        y        -23.813        z        57.493
x        187.506        y        -26.413        z        57.204
x        189.157        y        -21.594        z        57.053
x        190.919        y        -24.196        z        56.772
x        192.544        y        -19.331        z        56.612
x        194.306        y        -21.941        z        56.337
x        195.912        y        -17.04        z        56.171
x        197.674        y        -19.658        z        55.897
x        199.266        y        -14.728        z        55.728
x        201.027        y        -17.356        z        55.451
发表于 2014-3-20 23:04:37 | 显示全部楼层
把X,Y,Z 去掉,用空格分开,试试。
 楼主| 发表于 2014-3-21 08:04:10 | 显示全部楼层
就是因为试过沒有xyz的坐标点,那样也无法在实体设计中输入3D样条线。谁有从外部输入TxT文本格式的3D样条曲线的经验啊???跪求!!!
发表于 2014-3-21 09:10:56 | 显示全部楼层
采用输入”标题定义曲线“功能,类似如下格式的*.dat文件没有问题
SPLINE
361
0,0,0
0.0000000000004,0,0
0.00000000011,0.0000000000038,0
0.0000000028104,0.0000000001473,0
0.0000000279632,0.0000000019554,0
0.0000001658373,0.0000000145089,0
0.0000007086975,0.0000000744871,0
0.000002414774,0.000000296497,0
0.0000069689157,0.0000009794172,0
0.0000177112602,0.000002805188,0
0.0000407083316,0.0000071779772,0
0.0000862397205,0.0000167633035,0
0.0001707676809,0.0000362977911,0
0.0003194465495,0.000073750047,0
0.0005692139528,0.000141920978,0
0.0009724866026,0.0002605769998,0
0.0016014605397,0.0004592114202,0
0.0025529895657,0.0007805272397,0
0.0039539870498,0.0012847282711,0
0.0059672661834,0.0020546945228,0
0.0087977030267,0.0032021020317,0
0.0126985764113,0.0048745267805,0
0.0179779099801,0.0072635471177,0
0.0250046154802,0.0106138295603,0
0.0342142139179,0.0152331494815,0
0.0461138933745,0.0215032616279,0
0.0612866500784,0.0298914964873,0
0.0803942535559,0.0409629181798,0
0.104178777997,0.0553928388399,0
0.1334624508782,0.0739794445508,0
0.1691455866766,0.09765625,0
0.212202398295,0.1275040643987,0
0.2636745114671,0.1647621210955,0
0.3246620475917,0.2108379989291,0
0.3963121875681,0.2673159458431,0
0.4798051825104,0.3359632056658,0
0.5763378356928,0.4187339481294,0
0.6871045425625,0.517770410892,0
0.8132760407962,0.6354008810563,0
0.9559760887145,0.7741341727572,0
1.1162563563045,0.9366502968744,0
1.29506987702,1.1257870686388,0
1.49324346874,1.3445224583748,0
1.7114495871293,1.5959525591621,0
1.9501781225596,1.8832651218301,0
2.209708691208,2.209708691208,0
2.490084000607,2.5785574665134,0
2.7910848885691,2.9930721015243,0
3.1122076410936,3.4564567549456,0
3.4526441888328,3.9718127962085,0
3.8112657624955,4.5420896647853,0
4.1866105549999,5.170033469889,0
4.5768758923867,5.8581340000465,0
4.9799153568797,6.6085708864551,0
5.3932412347657,7.4231597282711,0
5.8140325799841,8.303299040238,0
6.2391490927746,9.2499189216792,0
6.6651509129956,10.2634323694587,0
7.088324321598,11.3436901648948,0
7.5047132332077,12.489940254952,0
7.91015625,13.7007925208085,0
8.3003289342925,14.9741897819248,0
8.670790846881,16.3073858212118,0
9.0170367924372,17.6969311373637,0
9.3345516145861,19.1386670348061,0
9.6188677938068,20.6277285512851,0
9.865625023134,22.1585565995086,0
10.0706308716729,23.7249195643682,0
10.2299215958364,25.3199444533341,0
10.3398221243662,26.9361575470654,0
10.3970042266745,28.5655343427625,0
10.3985418756018,30.1995584270904,0
10.3419628356928,31.8292887614902,0
10.2252955465749,33.4454347132889,0
10.0471104275994,35.0384380240749,0
9.8065548038379,36.5985607751317,0
9.5033807436968,38.1159782909507,0
9.1379652033644,39.5808758184209,0
8.71132199125,40.9835477333963,0
8.2251051944461,42.3144979598659,0
7.6816038467223,43.5645402414214,0
7.0837277611163,44.7248968812934,0
6.434984597163,45.7872945666623,0
5.7394483804119,46.7440559155526,0
5.0017198373306,47.5881854302781,0
4.2268790491788,48.3134486095603,0
3.4204310612543,48.914443061089,0
2.5882452064716,49.3866605660425,0
1.7364890121564,49.7265391751093,0
0.8715576540535,49.9315045597186,0
0,50,0
-0.8715576540535,49.9315045597186,0
-1.7364890121563,49.7265391751093,0
-2.5882452064716,49.3866605660425,0
-3.4204310612543,48.914443061089,0
-4.2268790491788,48.3134486095603,0
-5.0017198373306,47.5881854302782,0
-5.7394483804119,46.7440559155526,0
-6.434984597163,45.7872945666624,0
-7.0837277611163,44.7248968812933,0
-7.6816038467223,43.5645402414214,0
-8.2251051944461,42.3144979598659,0
-8.7113219912499,40.9835477333963,0
-9.1379652033644,39.5808758184209,0
-9.5033807436968,38.1159782909507,0
-9.8065548038379,36.5985607751317,0
-10.0471104275994,35.0384380240749,0
-10.2252955465749,33.4454347132889,0
-10.3419628356928,31.8292887614902,0
-10.3985418756018,30.1995584270904,0
-10.3970042266745,28.5655343427625,0
-10.3398221243662,26.9361575470654,0
-10.2299215958364,25.3199444533341,0
-10.0706308716729,23.7249195643682,0
-9.865625023134,22.1585565995086,0
-9.6188677938068,20.6277285512851,0
-9.3345516145861,19.1386670348061,0
-9.0170367924372,17.6969311373637,0
-8.670790846881,16.3073858212119,0
-8.3003289342925,14.9741897819249,0
-7.91015625,13.7007925208085,0
-7.5047132332077,12.489940254952,0
-7.088324321598,11.3436901648948,0
-6.6651509129956,10.2634323694587,0
-6.2391490927746,9.2499189216792,0
-5.8140325799841,8.303299040238,0
-5.3932412347657,7.4231597282711,0
-4.9799153568797,6.6085708864551,0
-4.5768758923867,5.8581340000465,0
-4.1866105549999,5.170033469889,0
-3.8112657624955,4.5420896647853,0
-3.4526441888328,3.9718127962085,0
-3.1122076410936,3.4564567549456,0
-2.7910848885691,2.9930721015243,0
-2.490084000607,2.5785574665134,0
-2.209708691208,2.209708691208,0
-1.9501781225596,1.8832651218301,0
-1.7114495871293,1.5959525591621,0
-1.49324346874,1.3445224583748,0
-1.29506987702,1.1257870686388,0
-1.1162563563045,0.9366502968744,0
-0.9559760887145,0.7741341727572,0
-0.8132760407962,0.6354008810563,0
-0.6871045425625,0.517770410892,0
-0.5763378356928,0.4187339481294,0
-0.4798051825104,0.3359632056658,0
-0.3963121875681,0.2673159458431,0
-0.3246620475917,0.2108379989291,0
-0.2636745114671,0.1647621210955,0
-0.212202398295,0.1275040643987,0
-0.1691455866766,0.09765625,0
-0.1334624508782,0.0739794445508,0
-0.104178777997,0.0553928388399,0
-0.0803942535559,0.0409629181798,0
-0.0612866500784,0.0298914964873,0
-0.0461138933745,0.0215032616279,0
-0.0342142139179,0.0152331494815,0
-0.0250046154802,0.0106138295603,0
-0.0179779099801,0.0072635471177,0
-0.0126985764113,0.0048745267805,0
-0.0087977030267,0.0032021020317,0
-0.0059672661834,0.0020546945228,0
-0.0039539870498,0.0012847282711,0
-0.0025529895657,0.0007805272397,0
-0.0016014605397,0.0004592114202,0
-0.0009724866026,0.0002605769998,0
-0.0005692139528,0.000141920978,0
-0.0003194465495,0.000073750047,0
-0.0001707676809,0.0000362977911,0
-0.0000862397205,0.0000167633035,0
-0.0000407083316,0.0000071779772,0
-0.0000177112602,0.000002805188,0
-0.0000069689157,0.0000009794172,0
-0.000002414774,0.000000296497,0
-0.0000007086975,0.0000000744871,0
-0.0000001658373,0.0000000145089,0
-0.0000000279632,0.0000000019554,0
-0.0000000028104,0.0000000001473,0
-0.00000000011,0.0000000000038,0
-0.0000000000004,0,0
0,0,0
SPLINE
CLOSED
发表于 2014-3-21 09:16:18 | 显示全部楼层
LZ,我截取了你数据的一部分试了一下,是可以生成3D曲线的
发表于 2014-3-21 09:20:29 | 显示全部楼层
首先激活三维曲线,然后在
snap.jpg 选择输入样条曲线
弹出这样的对话款
132.JPG 选择存有坐标的txt文件就可以了
 楼主| 发表于 2014-3-21 12:45:27 | 显示全部楼层
谢谢大家了!我用的是试用版的CAXA实体设计2013,估记是因为这个原因吧!
 楼主| 发表于 2014-3-21 22:16:41 | 显示全部楼层
谢谢福特司令官!谢谢大家!试用版的CAXA实体设计2013也能读入文本文件绘制样条曲线,只是文本文档中的坐标点数据要用逗号隔开!!!
GMT+8, 2024-11-16 00:29 , Processed in 0.201907 second(s), 24 queries .
