查看: 11868|回复: 13
R4增加的功能
发表于 2012-4-5 21:30:00 | 显示全部楼层 |阅读模式
R4终于发布了,但没有介绍增加什么功能或改进了哪些方面,最好有个介绍。<br>下载后在软件中看到的更新功能<br><br>CAXA实体设计2011r4新增功能<br><font size="3">1.IGES输入接口改进</font>支持读入三坐标测量机测量的点云数据,并按颜色分组<br>
<p align="center"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image002.png" width="450" height="315"></p>
<p align="center"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image004.jpg" width="465" height="336"></p>
<p align="center"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image006.jpg" width="417" height="243"></p><br><font size="3">2.批量读入圆柱坐标系点的功能</font>可以通过文本文件批量读入柱坐标系的点,下面是文件格式:<br>
<p align="center"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image008.jpg" width="321" height="182"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image010.jpg" width="187" height="166"></p><br>
<p align="center"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image012.jpg" width="465" height="114"></p><br>
<p align="center"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image014.png" width="408" height="223"></p><br><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image015.png" width="266" height="34"><font size="3">3.表面匹配功能支持工程模式</font>
<p align="center"><font size="3"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image017.jpg" width="225" height="203"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image019.jpg" width="296" height="204"></font></p><font size="3"></font><br><font size="3">4.变半径倒角功能的改进</font>改进了变半径倒角的效果,使倒角更加光顺,如下图:<br>
<p align="center"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image021.jpg" width="553" height="236"></p>
<p align="center">改进前</p>
<p align="center"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image023.jpg" width="554" height="198"></p>
<p align="center">改进后</p><br><font size="3">5.曲面裁剪功能增强</font>新添加了“生成新结果”的选项:如果此选项勾上,则将参与运算的“体”隐藏掉(如果参与运算的是面或者线则不会被隐藏),然后生成一个新的裁剪之后的结果。<br><br>
<p align="left">新添加“根据法向”的保留策略:根据裁剪工具的法向进行裁剪。其中“目标的另一边”和“工具的另一边”分别来控制保留的部分。</p>
<p align="center"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image025.jpg" width="153" height="352"></p><br><br><font size="3">6.Pro/E接口的改进</font>支持导入Pro/E隐藏体<br>支持导入Pro/E基准面<br>支持导入Pro/E草图及曲线<br>
<p align="center"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image027.png" width="476" height="333"></p><br><br><font size="3">7.鼠标手势</font>
<p align="left">可以同过鼠标的移动方向来执行相应的命令;</p>
<p align="center"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image029.png" width="438" height="312"></p><br><font size="3">8.支持自定义“S”快速访问命令菜单</font>
<p align="left"><font size="3"></font></p><font size="3">9.支持自定义选项卡命令的下拉列表</font>
<p align="center"><font size="3"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image031.png" width="392" height="260"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image032.png" width="113" height="175"></font></p>
<p align="left"><font size="3"></font></p><font size="3">10.面移动支持多零件</font>
<p align="left">新版本支持选中不同零件上的面执行面移动功能</p>
<p align="center"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image034.jpg" width="395" height="270"></p><br><font size="3">11.测量工具的增强</font>
<p align="left">支持测量线和线、点和线、点和面、线和面、面和面之间的最小距离、最大距离</p>
<p align="center"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image036.jpg" width="429" height="275"></p><font size="3">12.交互的改进</font>
<p align="left">使用右键菜单或快捷键(Alt+Enter)重复以前执行的命令</p>
<p align="center"><img border="0" alt="" src="mk:@MSITStore:D:\Data\桌面\下载\CAXAIRONCAD2011_Web_x86\Documents\What'sNew\zh-CN\CAXAIRONCAD_2011r4_New_Feature.chm::/CAXA2011r4/image037.png" width="359" height="138"></p>
<p align="left">命令中键入的值默认被保留:比如在倒角时键入了3mm,这个值将一直在倒角命令中保留除非键入新的值或重新启动软件</p>
<p align="left">生成剖视图、剖面图自动放置视图名称,以前版本需要手工指定放置位置</p><br><font size="3">13.数据接口升级</font>Pro/E接口:支持Cero 1.0<br>Solidworks接口:支持Solidworks 2012<div><br></div><div>更新说明: CAXA实体设计2011r4更新说明.pdf (903.61 KB, 下载次数: 25255) </div><div>集成的电子图板同时更新到2011r4</div>
发表于 2012-4-5 21:31:00 | 显示全部楼层
是啊,应该介绍明白一点,附带的电子图板更新了吗?
发表于 2012-4-5 21:54:00 | 显示全部楼层
R4终于发布了
发表于 2012-4-5 21:59:00 | 显示全部楼层
欢迎啊
 楼主| 发表于 2012-4-5 22:44:00 | 显示全部楼层
CAXA实体设计2011r4新增功能<BR><BR>1.IGES输入接口改进<BR>支持读入三坐标测量机测量的点云数据,并按颜色分组<BR><BR><BR><BR><BR><BR><BR><BR><BR><BR>2.批量读入圆柱坐标系点的功能<BR>可以通过文本文件批量读入柱坐标系的点,下面是文件格式:<BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR>3.表面匹配功能支持工程模式<BR><BR><BR><BR><BR>4.变半径倒角功能的改进<BR>改进了变半径倒角的效果,使倒角更加光顺,如下图:<BR><BR><BR><BR>改进前<BR><BR><BR><BR>改进后<BR><BR><BR><BR>5.曲面裁剪功能增强<BR>新添加了“生成新结果”的选项:如果此选项勾上,则将参与运算的“体”隐藏掉(如果参与运算的是面或者线则不会被隐藏),然后生成一个新的裁剪之后的结果。<BR><BR><BR><BR>新添加“根据法向”的保留策略:根据裁剪工具的法向进行裁剪。其中“目标的另一边”和“工具的另一边”分别来控制保留的部分。<BR><BR><BR><BR><BR><BR><BR><BR>6.Pro/E接口的改进<BR>支持导入Pro/E隐藏体<BR><BR>支持导入Pro/E基准面<BR><BR>支持导入Pro/E草图及曲线<BR><BR><BR><BR><BR><BR><BR><BR>7.鼠标手势<BR>可以同过鼠标的移动方向来执行相应的命令;<BR><BR><BR><BR><BR><BR>8.支持自定义“S”快速访问命令菜单<BR><BR><BR>9.支持自定义选项卡命令的下拉列表<BR><BR><BR><BR><BR>10.面移动支持多零件<BR>新版本支持选中不同零件上的面执行面移动功能<BR><BR><BR><BR><BR><BR>11.测量工具的增强<BR>支持测量线和线、点和线、点和面、线和面、面和面之间的最小距离、最大距离<BR><BR><BR><BR>12.交互的改进<BR>使用右键菜单或快捷键(Alt+Enter)重复以前执行的命令<BR><BR><BR><BR>命令中键入的值默认被保留:比如在倒角时键入了3mm,这个值将一直在倒角命令中保留除非键入新的值或重新启动软件<BR><BR>生成剖视图、剖面图自动放置视图名称,以前版本需要手工指定放置位置<BR><BR><BR><BR>13.数据接口升级<BR>Pro/E接口:支持Cero 1.0<BR><BR>Solidworks接口:支持Solidworks 2012
发表于 2012-4-5 22:50:00 | 显示全部楼层
感觉是不是图挂啦
发表于 2012-4-6 07:54:00 | 显示全部楼层
依你的介绍改的和提高的不多。
发表于 2012-4-6 08:26:00 | 显示全部楼层
你们看的见图么?我一张看不到
发表于 2012-4-6 08:44:00 | 显示全部楼层
下载安装以后有更新说明。
发表于 2012-4-6 09:56:00 | 显示全部楼层
还没下载,先看看更新
GMT+8, 2024-11-14 13:45 , Processed in 0.171702 second(s), 22 queries .
