查看: 2828|回复: 0
增强请求 - 如果复制和移动命令也适用于视图,那就更好...
发表于 2023-3-17 10:43:13 | 显示全部楼层 |阅读模式
Hi folks,
It seems like not impossible, as I can use Strech commands to move views and other objects together.
When I need to copy them all, I use Ctrl+C, Ctrl+V. But it would be nice if it was possible with Copy command, it would make it easier to position them.
GMT+8, 2024-11-27 21:46 , Processed in 0.171690 second(s), 18 queries .
